Old 07-26-2017, 01:28 PM
cycleguy55's Avatar
Originally Posted by gleslie View Post
Hello, I would like to increase the ground clearance on my year 2000 B&B cobra.
The front springs has spacers in it from the original owner. (do they compress in 'only' 17 years ?) I'm OK with sacrificing some good looks to get additional clearance. Do I need new taller / stronger springs ?
My 8 qt oil pan is 6.5 inches deep in front and 7.5 inches deep in the rear. Are there other 6 qt or more oil pans that would provide more ground clearance and also be OK with my 4 or 4.25 inch stroke ?
Let me know what you think I should consider.
Thank you, George
Take a look at Armando's #408 oil pan for the FE in a Cobra: It's 5" deep in front and 6 " deep in the rear - fully 1.5" higher than what you have now. It has kickouts and is 12.5" wide. Fully baffled for road racing use and comes with the pickup tube / screen and crank scraper. Make sure you get one built with an oil temperature bung, even if you have no immediate plans to use it.
Road race oil pan
Brian
