Old 07-28-2017, 09:43 PM
Cobranut Cobranut is offline
Cobra Make, Engine: Genuine original Unique MotorCars 427 S/C, with a Genuine original Ford 427 Side-oiler.
Send a message via Yahoo to Cobranut
If the ERA fans are the original type, approx 10" diameter unshrouded aluminum pusher fans, they're more ornamental than functional.
Better to ditch the flex fan, and use a pair of good electric puller fans in a shroud which fits your radiator properly.
Use the largest fans that will fit properly.
I have both, the original type and two pullers behind the radiator. My 12.5: 427 will sit in traffic in extremely hot weather literally forever. I've never seen the temp exceed 210* with a 180* thermostat, and the fan controller set to turn on around 190*.
David
