Old 07-31-2017, 02:38 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Rear shock mount inspection and possible replacement is really mandatory not for the bottom of the list. Your shocks are quite old at this point, but it's not like its a 3800 lb. daily driver with 80000 miles on it. People like the QA1's who have made the change. Same goes for the ball joints, springs and sway bars. Everyone I know who has upgraded them have been pleased with the results but lighter in the pocketbook for sure. The Shimmy, well, that could be a lot of things: tires, rims, alignment, front axles, etc.... no guarantees on that issue disappearing.... pretty much trial and error on that one. Check you wiring, add a correct kill switch, and relay for electric fuel pump. Roll bar needs an additional bolt on outside leg. But first inspect the rear shock mounts. Perhaps track the cars a little first to find problems and then make changes. Car may outperform its driver as it sits?
If it ain't broke don't fix it....
Blas
SPFWiringDiagrams@Comcast.net
