Thread: Tire Balancing
  #29 (permalink)
Old 08-02-2017, 05:32 AM
lnfletcher's Avatar
lnfletcher lnfletcher is offline
Cobra Make, Engine: B&B 427 Stroked Windsor TKO 600 w/3.50 posi 9"
Originally Posted by jhv48 View Post
Tom, here's another thought. The Nitto 555 G2's are harder ( treadwear 320 as opposed to 240) than your previous F1's. Try lowering the tire pressure to around 18 lbs. and see if that helps. I always try to stay with tires that have a 200 treadwear (soft) and keep my pressures down to 21-22 lbs.
Also, are you sure it's the fronts vibrating and not the rears?
I went through everything you've done. I replaced the wheels, tires, ball joints, tightened up the steering, replaced the shocks, and balanced and aligned the front end many times.
I finally found a pro who had the hunter road force GSP 9700 balancing machine. He spent some time and after rotating the tire to match the wheel, my problems were solved. If your guy isn't using that machine, find one that does.
It's the tires/balance. Our cars are so light, they need the wheel and tire to be a perfect match.
The key word is "pro"! I agree with jhv, it took the right tech (in my case the manager) to work the machine (road force) and figure out that it was causing a problem. I had to leave it with him for a day and I think he spent most of it working on my car but he found it. He did the same with mine as was suggested above, rotating the tire to offset the wheel. He charged me the same as a normal balance, but did get to drive a cobra a number of times to test it!
