Good to hear you are using the table as it is intended.
Many do not understand the use of more timing if the engine starts to die.
Lower vacuum after cold start benefits from more timing.
You can get almost EFI idle speed control at idle, cold and hot, if using the table to it's capabilities.
Gary
