Old 08-10-2017, 10:58 AM
spdbrake spdbrake is offline
Since ratios can be expressed as percent or fractions, the faster you go the larger the error you'll see.
Tire dia chosen is usually the 1st factor people experience in this issue.
I had plenty of issues on 4wd truck and large tires over the years. In some cases I lived with the error once I knew whats it was and in others I changed pick-off gears.
This article may help explain the factors.
https://www.thrillist.com/cars/your-...-japanese-cars
Speedo error calculator
Newer VDO, Autometer, Speedhut speedos can usually be custom recalb on a specific measured distance driven by the consumer.
