  #111 (permalink)
Old 08-11-2017, 04:15 AM
blykins blykins is offline
You don't need forged, and scat doesn't make a steel 428 crank anyway.
I personally would go with a 4.250, and yes, when you add 30-60 cubes, the cam selection will change. The cam you have will be much milder with a larger engine. If that's something you can deal with, then no need to change. Also no problem with mixing manufacturers if you do change.
Save the $500 that you would spend on a steel crank, get a cast 4.25 stroke, and buy a new set of rods and piston rings with the money.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
