  #112 (permalink)
Old 08-11-2017, 06:08 AM
patrickt patrickt is offline
You don't need forged, and scat doesn't make a steel 428 crank anyway.
I personally would go with a 4.250, and yes, when you add 30-60 cubes, the cam selection will change. The cam you have will be much milder with a larger engine. If that's something you can deal with, then no need to change. Also no problem with mixing manufacturers if you do change.
Save the $500 that you would spend on a steel crank, get a cast 4.25 stroke, and buy a new set of rods and piston rings with the money.
Doug, you should listen to Brent, he's much brighter than I am on these matters. But, I will throw this in: I know you're younger than I am (because I've met you) and I know you run your car harder than I do mine (because you break it every couple of years). If you don't want to do all of this again, err on the side of "less is more" on your rebuild. A slightly shorter stroke, slightly less cam lift, and slightly less power, will let your engine live longer and, that way, the next "major rebuild" will be undertaken by your heirs.
