Originally Posted by Aussie Mike
I reckon I'd be looking for a Holden cross 8 gearbox and front diff. Should be able to adapt it to the Audi motor. Cross 8 has a transfer case on the back and a shaft going forward.
The problem is Mike that you have to lift the motor far enough to clear the drive shaft, especially a wide engine such as the Audi V8, thereby loosing the centre of gravity and bonnet clearance etc...
This has always been the problem for this type of car, however the real benefit that the Audi transaxle has over the Cross 8 is gearbox is the Torson diff that transfers power front to rear much like a Tru-Trac diff from wheel to wheel, so when you load one of these Torson diffs up it gives you 66% rear drive and 34% front, and under normal driving 50/50, then under heavy deceleration it transfers up to 80% drive to the front wheels, hence why I am looking to keep the Audi system, including ESC, ABS and traction control + body control modules etc..
