If the front hubs are Mustang II, there's only one set of wheel bearings with the stock brakes: A12/A13. They may have changed the rotors/calipers because the MII brakes were tiny (~10" diameter, I think). If so, the bearings might be different. Measure the rotor diameter first. You might look through the pictures on rockauto.com to match up to what you have and/or take your stuff apart to check on the part numbers.
