  #65 (permalink)
Old 08-17-2017, 12:24 PM
cycleguy55's Avatar
Originally Posted by Speedwaypj View Post
It's obvious the electric fan (Mark VIII) seems to be the best option...or one similar in CFM.
However, "The reason that I am running a mechanical fan is to move more air through the engine compartment to try to relieve the inherent heat of a Cobra"........ So many of the articles over the years talk about heat trapped in the engine compartment.....I'm not worry about HP...it'll be fine!
SO, I'll need some type of electrical fan (Mark VIII) to help out the Mechanical Fan...to keep it cool....
Maybe I'll get one shortly just to satisfy myself....before I mount the body..
(cycleguy55 - Sorry about Grandma!)
Thanks all, some very good info and thanks to ByronRACE and cycleguy55 for references for parts!
PJ
Based upon what I see in your video ( https://www.youtube.com/watch?v=JTcaeBe7fAg ) it appears you have lots of room to install an electric puller. You could pull the shroud, install the fan, and re-install the shroud. You'd have the cooling you need for crawling in traffic and the mechanical fan to keep air moving through the engine compartment at all times.
Good luck.
Brian
