  #210 (permalink)
Old 08-19-2017, 07:46 PM
1795's Avatar
1795 1795 is offline
Bill,
Glad that you got the engine installed, sorry to hear that you will have to install the transmission from underneath. That is a lot of work. Do you have the tunnel installed at this point? If not, you might be able to have someone help from above you and assist with maneuvering and holding the transmission. On my build I was able to leave the transmission cross member in place and bring the transmission in form the passenger compartment with the tunnel removed. We were able to balance the transmission on the crossmember while I was underneath and then line the transmission up with the bell housing and get it in place.
Not sure if that will be possible with your situation. Those things are heavy and a pain to maneuver, even with a transmission jack. Good luck and be careful.
Jim
