  #178 (permalink)
Old 08-22-2017, 01:32 PM
patrickt patrickt is offline
Originally Posted by dcdoug View Post
Here are the cam specs:
Custom Comp Cams solid flat tappet:
291/299 advertised duration, 254/262 @ .050", 108 LSA on 104 ICL, .584"/.602"
That's beefier than what you've got now. The "advertised duration" of your current cam is 324 degrees (IIRC), but they measure it from a different spot, so you really can't compare it easily. The .050" numbers are significantly harrier than 245/245 106 LSA and .500" lift after your lash is taken out.
