Originally Posted by Texasdoc
Another thought is to make sure you connected the new Summit 6AL box to the distributor correctly. Does your distributor have green and violet wires or two black wires? MSD in their infinite wisdom made the wire colors wrong. If you have two black wires, make sure the black wire with the orange stripe connects to the violet wire on the Summit box. The black wire with the violet stripe goes to the green wire. The black wire with the violet stripe DOES NOT go to the violet wire!
My distributor has one wire that's black with green and the other is black with violet. The black wire with the orange stripe is connected to the violet wire on the Summit box, and the black wire with the violet stripe goes to the green wire. The polarized plug and colour coding on the wiring is exactly the same as MSD so therefore pretty difficult to get wrong. That's not surprising considering MSD makes these boxes for Summit.
