Old 08-25-2017, 03:34 PM
stephen low's Avatar
stephen low stephen low is offline
Chris
Am running an Odyssey PC925, 330 CCA which is fine for the 5L Windsor and quite a small sized battery for its punch.
These are a sealed and can be mounted in any configuration except inverted, so on their sides if needed for space reasons.
They do a large range of other models with even higher cold cranking and pulse crank ratings as per the link below.
Extreme Series Battery Specifications
slowy
