Originally Posted by tortuga
I was thinking as much as bowls come on and off, and judging by all the thread repair kits available, why not fabricate some 10-24 studs for the bowls? It would also make threading on gaskets, metering blocks etc quite easy. Hold it together with nylons and the regular screw gaskets...
The reason there are so many thread repair kits available is because guys over-torque the screws. It's not hard to do, considering the torque value is only 25 to 30 inch/pounds. I now always use a pointer type, not click type, torque wrench that goes down that low when I put the bowls back on. I've cracked bowls before when I didn't use a torque wrench and my hands and wrists can't really judge torque values that low. So, the bottom line is
you don't need studs, just don't over-torque the screws and they'll last forever.
