427 FE, All Aluminium, just delivered, with TKO 600, Quicktime and McLeod clutch kit.
Hi guys. I'm in the UK and have taken delivery of the above motor this week. Its neutral balanced, so has a uniform, unweighted steel flywheel.
I'm assembling the clutch unit, which is a McLeod 12" 75236 Super Street Pro, 12" (Ford) .
My question (there are no instructions) is regarding attaching the pressure plate to the flywheel.
It seems it needs 6 x 5/16" bolts, with no dowels. Can anybody confirm this is correct? Also do I need to use threadlock and sprung washers under the bolt heads?
Same applies about flywheel bolts (washers, threadlock or not) which are 7/16.
Many thanks
