Old 05-26-2002, 03:03 PM
tblackgt350 tblackgt350 is offline
Default 289 ida idle jetting
Could someone out there advise of where I'm going wrong with my idle circuit? I'm running a 289 .030 over with 10:1 compression. I've got a solid cam with 238 degrees duration. I'm running 48 idas with : idle jets .60 idle jet holder 120, main jets 155, air correctors 210. Chokes are 37mm. The idle jets are engraved with only one number, 60, not 60 f8 if this makes a difference. The floats are o.k. and at the same level. The carbs flow the same amount of air and the linkage appears to be correct.
The car runs great above 2900 rpm, but stumbles badly when pulling out, or trying to launch at about 2500 for a drag race start.
Any help would be greatly appreciated,
Thanks
tblackgt350
