Old 10-13-2017, 12:11 PM
DanEC's Avatar
DanEC DanEC is offline
Dan, it's only 100 lbs. -- just build a quick block and tackle hoist with 2 x 4 wood pieces and roller casters on the bottom. Use bolts to connect the pieces so you can easily disassemble them when you're done. With a weight that is only a hundred pounds, a 4:1 block and tackle will make it easy to lift up and the roller casters will let you roll it around to wherever you want it.
Patrick - I don't care what they do say about you, you do come up with some good ideas now and then. In this case you jogged my memory that I used my 4-post lift as a sort of jib crane to lift my GTX's 175 lb transmission down off of the transmission jack. I might be able to make that work again or maybe just fab up a little rolling hoist.
Hi Cobra - good point about draining the fluid - a Toploader does have a bottom plug to make that easy.
ERA 782 Running
