I need some idea's for a side glass, open/close handle setup...........
I'm just about finished with my LaMans top from Mr Bruce [thanks again], and I just finished a side window setup [LEXAN MARGARD SOLAR GRAY 1/4"] so I need some type of latch to hold it to the top.
The latch would be an easy thing to fab except that it needs to work from both sides.
Also, I would think that there is something out there I can use that is cheap enough so that it would be easier to just buy it vs the time to fabricate [using the primitive tools I have, as in no end mills, or lathes].
Here is the side window installed.
You can put a chebby engine into a Ford body, but it will NEVER be a chevrolet. It also shows you're ignorant, and lack imagination, as in its been done to death as in its not an original idea.
