Old 10-14-2017, 02:15 AM
Dominik's Avatar
Dominik Dominik is offline
Default Swivel fitting
The early Tilton were leaking around the swivel fitting - 20 years ago.
I would consider this fixed ;-)
I actually used a copper ring conversion which I tightened through holes which I drilled into the bellhousing.
It is very helpful if your chassis is close to the clutch slave cylinder or TO bearing lever. If you don't have a supplier for that slave cylinder bracket, it takes a bit of fabricating.
Time you can save by using the internal version.
If I don't respond anymore, that's because I can't log in
