  #38 (permalink)
Old 10-16-2017, 12:48 PM
cycleguy55's Avatar
Originally Posted by MOTORHEAD View Post
This will be short with no pics due to the slowness of this site, but I wanted to let all interested parties know that a test drive last Friday was successful , with low speed keeping water temp @ < 95C at stoplites, and high speed keeping it @ 80 C. and at 40mph, high will pull temp below 80C.
Re: current draw on low was < 20 amp, on high < 25 amp, measured with induction meter, and in-line meter, with high spikes at turn-on.
Are you using a fuse or a circuit breaker in your fan circuit? I set mine up with a self-resetting circuit breaker and a pair of relays in parallel - each relay can handle the load, but they share it in a redundant configuration.
Brian
