Old 10-18-2017, 03:13 PM
FWB's Avatar
FWB FWB is offline
contact Crites restorations, they sell a upgraded factory mount, the metal is a bit thicker, this will be a 3 hole mount, for added peace of mind instead of the drilling another hole in the mount, which gives you nothing, add a small heim on the front of the motor to the drivers cylinder head, attach the other end to the frame. this will guard body damage incase of a mount failure. note its not the bolts that fail, it will be the rubber separating from the mount, usually will occur on the drivers side.
Fred B
