Old 10-20-2017, 05:20 PM
FWB's Avatar
FWB FWB is offline
there are several FE mounts for the FE, depending on the frame mount, that will determine which you use in the car, but yes all of them will bolt up to the engine, but not all if any for that matter will bolt to the car, i like when a manufacturer takes availability of parts when they design their car. my car uses the mustang style. the frame mount can be used on a small block or a big block, i even added an additional welded appendage that will allow me to also install a 385 series motor(351C-460)
Fred B
