Thread: New coupe
Old 10-23-2017, 02:01 PM
cycleguy55's Avatar
Remember, a large cube small block has to work very hard, to get the same power of most big blocks. The 351/427ci sbf is real popular.
Unless I'm missing something, cubic inches are cubic inches. a large displacement small block shouldn't have to "work any harder" than a big block of the same displacement.
Some data:
  • FE (15 examples): 0.97 - 1.50 HP/CID, 1.08 - 1.32 ft-lbs/CID
  • Windsor (425 CID+, 4 examples): 1.14 - 1.49 HP/CID, 1.18 - 1.32 ft-lbs/CID
Worth noting from Brent's data is the top Windsor (445W, 1.49 HP/CID) was running less compression (10.7.1 vs 12:1) and less cam (0.700"/0.690" lift vs 0.760"/0.760") than the top FE (465 CID, 1.50 HP/CID).
There are no material differences, cubic inch for cubic inch.
Brian
