Old 10-29-2017, 02:55 PM
jetblue69's Avatar
jetblue69 jetblue69 is offline
Cobra Make, Engine: ERA #816, 427 Side Oiler
Thanks, need the control arm and half shaft dims though too... I have my rear all together and installed in the car. It looked a little odd to me before I installed it but figured it would be o.k. once it had weight on it. The rear wheels look like the front end of a 40's tractor (7.20 degrees positive camber both sides) the sway bar looks to be too wide to line up with the lower control arm mounting brackets and even with the coil overs adjusted all the way out there's still a huge angle in the suspension geometry. Calipers, rotors, all dead nuts where they should be unless I'm losing it and missed something. Everything is lined up in the cage where it should be. Even had my buddy take a look at it and we're both scratching our heads cause we're pretty seasoned gear heads.
Maybe someone can throw in their two cents...
