10-31-2017, 04:20 AM
KY
I can machine a block for you, get the rotating assembly here, and do all the bearing clearance checks/adjustments for you. The majority of the work in putting a SBF short block together is making sure the bearing clearances are correct and making sure the rotating assembly clears the block.
