Old 11-02-2017, 02:31 PM
stephen low's Avatar
stephen low stephen low is offline
Thanks guys that helps.
Have seen both gauges but will go the slightly heavier.
Have acquired a set of Bob's Vintage knock off rims and note he is also supplying safety pins that go into the end of the knock off shaft.
Realise this measure is way too late in terms of proper rim retention but I guess it does retain the spinner ultimately.
This stops the spinner become a projectile on the open road if the worst was to unfold.
Cheers and thanks
slowy
