Engine Position
Ive picked up the project started from 63Mercury of a scratch built cobra.
I was just about to fasten the body down, and was checking the wheel gaps, and header clearance when I determined the headers would not come out the openings in the body! There are many threads on this, but are mostly from full kits with all the mounts already in place on the frame. The body seems centered on the wheels, birdcage fits well, front and rear all look good.
It appears the engine needs to move rearward about an inch. Ive checked my driveshaft and looks like it will be ok to move the trans back and still have clearance into the trans (9" rear, T5, 302).
Im looking for a reference dimension for the engine in the frame to see where it should be. Does anyone have one?
Need to have some place to start - ideally a reference from either the front or rear wheel centerline to the engine mounts. Engine currently has the mustang hinge type motor mounts (as opposed to the stud mount).
Thank you
