Thanks guys.
I certainly intend to dial in the bellhousing. I spoke to engine builder and he says the bush supplied with the Mcleod Clutch kit, though slightly magnetic is perfectly fine. Looks like it bronze anyhow and I guess the iron is to make it more durable.
Just clearing some space now to make an engineering table where I can assemble the motor/drivetrain and mock up the mounts based on a dummy chassis I will construct from 4" dia plastic drain pipes. The car is fully assembled, been on the road for 24 years, so mount construction, not as easy as working on a body free chassis.
