tank sending unit
Use the search box to check on your questions, but I went through my gas tank and pulled the sending unit and just cleaned it up and reused the unit. Later I found, while searching, that the sending unit is GM and most likely a Chevy Chevette unit. Make sure you get a good ground on that sending unit or it won't work.
