I purchased one from Wema USA in Ft Lauderdale. I remove the tank and measured from opening to the bottom of the tank. You need to know the ohms values for the gauge your using in order to order one. They make a 2 wire sender which is one of the best I have found. Do not purchase the 3 wire sender as they are junk. You can also measure the sender you have in the tank. Simple to remove the tank. Be careful with the bolts attaching the sender as they are easy to strip out. If needed you can purchase a stainless split ring to go under the tank opening to screw the sender to.
