Old 11-19-2017, 01:42 PM
Mark IV Mark IV is offline
Senile Club Cobra Member
Originally Posted by jeclarke View Post
Will be receiving SP03174 in a few weeks and a Roush 427SW which i will install myself. I dont have a list of whats in the install box that comes with the car but i gather radiator hoses are not included. I would appreciate any info you have on what hoses to use. Pictures of your install would be great that show routing.
I have the same questions about fuel lines and the electrical box. I have ordered a wiring diagram.
Thanks!
The fuel line is a hard line that terminates about where a mechanical fuel pump resides and is affixed to the frame rail with a slight turnout towards the engine. All you need to add is the flex line and clamps. If you are using an electric pump a feed wire is routed to the rear of the chassis as well as a control switch on the instrument panel
All of the electrics are done as well. You will have coiled wires with terminal ends for the alternator. The voltage regulator is already supplied and wired in. The battery cables are in place in the boot and the cables for the starter are there as well.
Most of this is covered in the installation manual we sent you previously. (For the record we did not sell this chassis, but have provided information and will be pleased to continue to do so)
Good move on buying the wire diagram from Blas, money well spent that can save you hours and perhaps a "nasty".
rick@autoventureusa.net
