Old 11-25-2017, 06:13 PM
Large Arbor Large Arbor is offline
Cobra Make, Engine: ERA 714
Default System not charging
So a week or so ago I was on a cruise and noticed the voltmeter showing me the system was not charging. Came home and put spare alternator and voltage regulator on and it was working again. Went out today and had the same problem. Starting removing tape and looking at the wires which were all ok. Then found the feed wire to the battery from the alternator had a broken connector. Replaced that and it was back in business. I think it broken when one of the alternator bolts fell out a week or so ago and it torqued the alternator in a direction which caused the connector to crack.
All good to go now!
Phil
