Old 11-27-2017, 05:41 PM
mofo mofo is offline
Helpful info, I wasnt sure how much was built around the mustang II. I realized the early assembly items were. I do have a steering column that came with the kit. And a full wiring harness. I realize an ECM/ECU would be shaped by engine of choice, but I wasnt sure if you could allocate "Ford engine" in the kit purchase and it came with some of those other items.
Speaking of engine mounts, the mounts that came with the kit have a 3" spacing. I have a set of old engine mounts that I believe were off the 351W that I got with the car that have a 4" spread. When I order new engine mounts for the 351, can you shim with washers the difference in order to position the engine slightly front to back? Or do I need to find a different set of 351 mounts that fit the 3" spacing?
