Which Pilot Bearing?
I'm matching an FE to a 5-speed Tremec TKO. The FE is a 427 with a 428 crank. The tranny input shaft is 1-1/8" diameter with 26 splines. I'd like to use a roller-style bearing (but would go with a bushing if a roller isn't available), but have not been able to locate one that matches the requirements.
Any suggestions as to specific brands/part numbers?
Thanks.
