Old 12-04-2017, 09:14 AM
Danr55's Avatar
Danr55 Danr55 is offline
Not structurally important but not irrelevant. Even though they are just for show they are still subject to work hardening. As such may crack. Stress corrosion is always a consideration with aluminum. So you do not want to bend them into too small a radius. If you are using anything in T6 condition, annealing before bending is always a good idea. Aluminum will naturally harden after working and will become less maliable with age. I dont recall for certain but I believe the rule of thumb for bending aluminum was Minimum R(bend radius)= [1.5T(thicknecss) +.03]. So for .032 stock, the minimum bend radius would be .032 x 1.5=.048+.030=.078R.....or something like that..
Dan in Arizona
CCX3209
