Old 12-04-2017, 11:18 AM
Morris Morris is offline
Cobra Make, Engine: Kirkham #259
Dominik
I went thru many changes after we built the car.....
Talk@CobraRegistry.com
As you may or may not know, when you get on the track and go up to speed......you realize changes that need to be made by monitoring the heat ranges and reactions the vehicle makes. Then you go back to the car and start changing the many items in order to return to the track.
Above is where I started a thread on talk@cobra registry where did start making changes....for example we put 3 different oil coolers on the front before we found the one the kept our oil temp under control.......we changed 3 different filter systems until we found one we liked.....and 2 different power steering systems before we liked the way KMP259 reaction time was right.
These are the things people should be doing to their cars before they really start driving them on the street......but most are just happy to have them done in their mind.....not so....because they then find out later what works and what doesn’t work....
You may have to join the site to see all of the photo’s.....but it is well worth joining.....
Thanks for your inquiry and ask all the questions as it’s time for me to pass on info to the younger folks to help them perform safely.
Morris
