Although you will have more than 600 torque, I think you will be OK. For one you will not be able to hook it all to the ground in most gears. Two the TKO has some safety factor built into the rating. Three you are going to loose a bunch of power when you install it in the car. That said, I wouldn't recommend beating on it in 5th gear.
