Old 12-10-2017, 09:45 AM
CompClassics's Avatar
CompClassics CompClassics is offline
Cobra Make, Engine: SAI FIA, 289HP (5-bolt), 48IDA Webers
I believe Dan is emphasizing the dangers of the rotating mass (flywheel, clutch and pressure plate) and the proximity of it and the drivers and passengers legs. If something went wrong the possibility of personal injury may be more likely than if you used a scattershield or blow-proof type bellhousing, either cast steel or deep drawn steel.
