Originally Posted by not-a-number
I just want to get an idea of what a good road setup is so I can start changing things.
If you know some of your numbers it would be great to hear them.
Front Tyre Width:
Rear Tyre Width:
Camber:
Toe (in/out):
Caster:
Front Spring Rate:
Rear Spring Rate:
What chassis? What suspension? That will make a huge difference in the settings. What works on an original design big-block chassis, doesn't on a transverse leaf spring system. More data is required for hal9000 to evaluate.
