I am not sure what engine yo have but if it is a normally aspirated one then the PCV setup is simple. From the left front valve cover all you need is a hose from the breather cap to the air cleaner housing and on the right valve cover from the rear breather to either an inlet on the carb spacer or an inlet in the intake manifold. This picture shows mine from the left valve cover tom the air cleaner and my left cover has the same hose through a PCV valve that plugs into the valve cover and then goes to the spacer under the carb.
