Old 12-20-2017, 11:42 AM
DanEC's Avatar
DanEC DanEC is offline
Do you know if you have a spring in your lower hose to keep it from collapsing under suction? I found an old one and used in mine when I put it together which sort of stiffened the hose up a little. If not and if you aren't having any flow or coolant problem it's probably not worth messing with right now.
ERA 782 Running
