Thread: which cam?
Old 12-23-2017, 04:28 AM
stroked windsor stroked windsor is offline
Default which cam?
402w. running the comp XR282RF which has 230 236 513 526 and 110. original cam used was a custom HR cam 240 248 624 600 110 that cam made over 560 hp with 1" spacer, new cam made 540 with out..both made the same torque 535. only thing is the smaller cam torque curve is a bit lower for street. peak on the big cam was@5400. small cam @4900 AFR205 heads. vic jr with a 950. thinking maybe because the lift is higher with that bigger cam would match the heads better? small cam is done by 500 lift.. could I advance the bigger cam 2 to 4 degees? I do have a 8" converter with 3000 to 3500 stall. street 69 mach1. my mechanic has this car dialed in now.. said just leave it alone.. motor has only maybe 100 miles test and tune.. many dyno runs..
