Regarding fit - if everything else about the car is what you want but the fit is a little off you need to consider that unless this is your first Cobra fitting yourself comfortably in these cars is a challenge. Only with some seat time does one become more and more comfortable in the car. That being said, if you fit but it's off a tad here and there many of these cars can be easily modified to accommodate some fitment barriers. Some tricks include removing seat foam, using a smaller diameter steering wheel, removing seat adjustment sliders, changing the seat mounting angle, changing the steering column angle, changing the pedal positions, etc..
