Originally Posted by Mark IV
Aluminum tape over the oil cooler works well.
If your thermostat is working properly you should not need to block the radiator. The stat is intended to keep the system at the selected temp level, i.e. 180, etc. and that should be sufficient for proper heater operation.
That's a good point I wonder if I am due for a newt Tstat? She never exceeds about 90c but in cool weather never gets more than about Half way if moving?
Water does take a while to heat up wonder if it's sticking partial open...whelp new project...
Thanks MkIV
