[quote=Akimbeau;1435858]
Originally Posted by patrickt
After only 4k? Naaah, and the thrust bearing could have come from your transmission shaft sticking in too far.
This is one of the things I'll be checking when I get things back from the machine shop. Also, there are heavy machine marks on the thrust surfaces of the crank. Should these be more of a polished surface? I'm finding other questionable engine build techniques like using 50g balanced flywheel and harmonic balancer on a 28g crank. They drilled the bejesus out of them to get a balance or close to balance, who knows. The engine never seemed to run smoothly since I bought the car.
Can you post a photo of these "heavy machine marks"?
If the crankshaft has been reconditioned, there should not be machining finish visible on a bearing surface.
Gary
