I bet a Google search would lead to a calculator where you could input the transmission gear ratio, rear end ratio, and tire diameter to see the speed at any given RPM. Change the numbers to see the difference between 4th and 5th gear with each rear end ratio. Then decide which compromise best fits the way you drive where you are.
Tommy
Previously owned EM Cobra
