  #39 (permalink)
Old 01-09-2018, 12:40 PM
Roger Bolick Roger Bolick is offline
Cobra Make, Engine: Exact427
Obvious difference in OLD vs NEW (have not seen Retro-uk OR Moss) is the metal roll at the top, side, and bottom. As mentioned previously, the weight of the old ones is twice or more of the newer ones. The NEW "rolls" look... petite. The Old rolls are bold.
The NEW metal is much thinner.
Moss does not mention wall thickness, hopefully they copied this aspect.
Thin metal sides flex with the clamps & movement thus popping the joints.
Fill these containers 1/4 full or less, enough to cover the bottom and make it easy to see if you still have a "lake" or the "drain" is visible. This lessens the mess if it leaks. Ample brake fluid in the long line to the master.
