Old 01-15-2018, 05:53 AM
DanEC's Avatar
DanEC DanEC is offline
If your car is down for the winter giving you some time, you might put a hose clamp around the seal and tighten it up and let it set for a week or so to compress the seal a little. Then lube it up and try again. Otherwise I would suspect the seal in that particular kit is not in spec and you may need to try another source.
ERA 782 Running
